JSON Utilities
With the “JSON Utilities” library, data can be read and written in JSON format from a CODESYS controller.
The library “JSON Utilities” is now part of the product IIoT Libraries SL and is no longer available as single product.
1.0.1.6
2111000024
The ‘JSON Utilities’ library provides the following functionalities:
  • Read JSON files (UTF-8 and UTF-16)
  • Read JSON byte arrays
  • Write JSON files (UTF-8 and UTF-16)
  • Search for keys, values, and child and parent elements
The data is stored in an array of structures. Data access and element search is performed by means of methods from the JSONData function block. The function blocks JSONByteArrayReader and JSONFileReader read data in JSON format and save the values in the JSONData function block. Writing files and byte arrays is performed by means of the function blocks JSONFileWriter and JSONByteArrayWriter.
A simple REST client can be implemented easily in connection with the library ‘Web Client’ (available in the CODESYS Store).
CODESYS Control V3.5.14.0
Workstation license
Version Release Notes
Release Date
Bugfix for 64 bit devices.
10.06.2020
Reviews
Write Your Own Review
