INI File Utility
The product “INI File Utility” is a library to read and write INI files.
The library “INI File Utility” is now part of the product IIoT Libraries SL and is no longer available as single product.
2111000007
The product “INI File Utility” is a library to read and write INI files. The library contains function blocks to read, write and find values of INI files. An example project shows the usage of the library and their function blocks.
Content of the package:
  • Library INIFileUtility (Namespace: INI_UTIL)
  • Example project with visualization to read, write and find values of INI files
  • CHM help file
CODESYS Control V3.5.14.0
Workstation license
Reviews
Write Your Own Review
