CSV Utility
SKU
2111000006
The library CSV Utility enables the reading and writing of CSV files with a CODESYS control.
The library “CSV Utility” is now part of the product IIoT Libraries SL and is no longer available as single product.
The library CSV Utility provides function blocks to read and write CSV files. The library contains the components CSVReader (read a CSV file) and CSVWriter (write a CSV file). All function blocks can be used in a classical or object oriented way. An example project demonstrates the usage of all components.
CODESYS Control V3.5.14.0
All
Workstation license
sales@codesys.com
Reviews
Write Your Own Review
