CODESYS Test Manager Demo
4.3.0.0
SKU
2101000003
The CODESYS Test Manager enables the programming and execution of automated tests of applications and libraries developed with CODESYS (32/64 Bit).
The CODESYS Test Manager is part of the tool bundle CODESYS Professional Developer Edition.
The CODESYS Test Manager allows the programming and execution of automated tests, above all of applications and libraries developed with CODESYS. This applies both for 32- and 64-bit variants.
The CODESYS Test Manager is the central component for test automation and management and it serves most primarily for the test of applications and libraries.
The CODESYS Test Manager supports tests of the following objects * Application * IEC libraries * Communication
CODESYS Development System V3.5.16.0 or higher
CODESYS Control V3.5.5.0 or higher
Subscription of the CODESYS Professional Developer Edition.
64 bit support with version 4.2.2.0 and higher
The following licenses are available:
  • Demo license: Time limited usage
  • Subscription license: Time limited usage
The following licensing options are supported:
  • Soft Key, with CODESYS Development System SP 13
    (Workplace-bound licensing, free part of all CODESYS products)
  • Optional: CODESYS Key
    (Increased security against loss of license keys, transferable licensing to other workstations)
Required accessories
Detailed compatibility information
Version
Programming System Version
4.3.1.0
3.5.16.0 - newest
4.3.0.0
3.5.5.0 - newest
4.2.4.0
3.5.5.0 - newest
4.2.3.0
3.5.5.0 - newest
4.2.2.0
3.5.5.0 - newest
4.2.1.0
3.5.5.0 - newest
4.2.0.0
3.5.5.0 - newest
4.1.0.2
3.5.5.0 - newest
sales@codesys.com
Version Release note
Release date
- 20.04.2020
Interoperability fix
  • The test progress bar is visible also with versions of the CODESYS Developemnt System 3.5.13.0 and higher.
19.07.2018
- 14.05.2018
CODESYS TestManager 4.2.2.0 is a bug-fix release.
It contains fixes to stabilize testruns.
06.11.2017
CODESYS TestManager 4.2.1.0 is a bug-fix release. It contains fixes of major-bugs for UnitTests and TestTables.
14.09.2017
- 25.07.2017
- 03.11.2016
Reviews
Write Your Own Review
