CODESYS Profiler Demo
1.3.1.0
SKU
2101000004
The CODESYS Profiler enables the detailed measurement of runtime behavior and code coverage at program block level.
The CODESYS Profiler is part of the tool bundle CODESYS Professional Developer Edition.
With the CODESYS Profiler, software engineers and application developers can perform an early measurement and evaluation of the processing times and code coverage of the different POUs in an IEC 61131-3 application. These measurements can be performed on the CODESYS SoftPLC or a physical device without changing the IEC 61131 application code in the project. Application development and measurement can be done in parallel in one and the same development environment.
Functionality
  • Dynamic measurement by instrumentation of code upon each function entry and exit after activating the runtime measurement in the development environment
  • Only during measurement: temporary code increase and prolongation of runtime by 10-50% dependent on PLC platform and program structure
  • Starting measurement via variable or on command
  • Clear presentation of measurement results on the development interface
Benefit
  • Performance and code coverage measurement of the machine code already at the beginning of the development phase
  • Timely notice of runtime issues
  • Identification of time consuming program parts and the portion of unprocessed statements
  • No modification of the application code by the user needed for measurement
  • Collective or single measurement of application POUs possible
  • Determination of code efficiency by comparing historical and current measurements
  • Improved software quality
CODESYS Development System V3.5.13.0 or higher
CODESYS Control V3.5.0.0 or higher
The runtime measurement is independent of platform and device (for all CODESYS Control Runtime devices).
Subscription of the CODESYS Professional Developer Edition.
  • Runtime measurement for IEC 61131 program parts only
  • Potential temporary code increase and prolongation of runtime by 10-50% dependent on PLC platform and program structure
  • Enabling or disabling the profiling feature or changing the profiling settings requires a download (online change is not possible).
  • Demo version: limited time and range of functions
  • 64 bit support with version 1.2.0.0 and higher
The following licenses are available:
  • Demo license: Time limited usage
  • Subscription license: Time limited usage
The following licensing options are supported:
  • Soft Key, with CODESYS Development System SP 13
    (Workplace-bound licensing, free part of all CODESYS products)
  • Optional: CODESYS Key
    (Increased security against loss of license keys, transferable licensing to other workstations)
Required accessories
sales@codesys.com
Version Changes Release date
Sampling for PLCs with multicore CPUs to avoid impact of the measurement algorithm on the application runtime.
12.02.2020
The user interface was renovated and simplified. The profiler is now an object under an application. All profiler results can be stored and loaded. Code coverage is a new feature supported by the profiler. It is possible to execute time measurements and code coverage on a defined subset of the POUs.
18.04.2019
 New function “Add to profiler watchlist”
New column “Instance” in the online mode (see “Select Online State”)
New text field with a description for each control in the dialog.
08.05.2018
CODESYS Profiler 1.2.0.0 is a bug-fix release, and now compatible with CODESYS Development System V3 64-Bit variant. 13.09.2017
This product version also runs on the Schneider Electric SoMM V4.4.
(For activation please by a widget type="Codesys\AllVersionWidget\Block\Widget\AllVersion" and download the supported software package.)
14.12.2016
Rework widget type="Codesys\AllVersionWidget\Block\Widget\AllVersion" handling 07.09.2015
  20.05.2015
Reviews
Write Your Own Review
