CODESYS Development System V2.3
The CODESYS Development System is an IEC 61131-3 programming tool for the industrial controller and automation technology sector.
CODESYS V2.3 is only available in the CODESYS Store until the end of 2022.
2.3.9.70
000082
The IEC 61131-3 engineering tool CODESYS Development System comes in Version 2.3 with a free trial version of CODESYS Control Win - a runtime system under Windows with full functionality.
System requirements
Windows XP/7/8/10 (32 Bit), suitable PC hardware for the used Windows platform.
Additional requirements
Required accessories
- 23.11.2022
Includes the following Security fixes: 2022-11, 2022-12, 2022-13
23.06.2022
Includes the following Security fixes: 2021-15, 2021-16, 2021-17
25.10.2021
- 15.07.2021
Includes the following Security fixes: 2021-06 2021-07 2021-08
11.05.2021
02.10.2020
Includes the following Security fixes: 2019-11
18.12.2019
Includes the following Security fixes: 2019-09
23.10.2019
12.09.2019
21.02.2019
CODESYS V2.3.9.57 is a security update, which solves the runtime issues noted in Advisory 2018-04.
For more details see:
In addition, this release fixes some usability issues in task configuration editor and in ST editor with intellisense:
LCDS-284 Task: Problem with Setting Debug Task
LCDS-278 Intellisense, Windows 10: Focus does not return after using Intellisense
20.04.2018
CODESYS V2.3.9.56 is a security update which solves the issue noted in Advisory 2018-01.
https://customers.codesys.com/fileadmin/data/customers/security/2018/Advisory2018-01_LCDS-282.pdf
30.01.2018
  27.09.2017
  02.12.2016
