CODESYS Control Win MC SL
CODESYS Control Win MC SL is an extension of CODESYS Control Win SL – an IEC 61131-3-compliant SoftPLC for PC-based industrial controllers running on Windows with soft real-time properties.
3.5.19.0
2302000030
€110.00
CODESYS Control Win Multicore SL extends an existing industrial PC, on which CODESYS Control Win SL is installed, to a multicore (MC) high-performance PLC. This can process its IEC application specifically on multiple CPU cores. The system is suitable for applications with soft demands on the real-time behavior.
Benefits
  • Extension of CODESYS Control Win SL for multicore support
  • Extension of the CODESYS Development System for binding individual IEC applications to different CPU cores
  • Debugging of the multicore application within CODESYS
Fieldbus support
The fieldbuses of CODESYS Control Win SL are supported in single-core operation.
Some fieldbuses require an installed Npcap. This product therefore includes software developed by the Computer Systems Engineering Group at Lawrence Berkeley Laboratory.
Product options
CODESYS Development System V3.5.17.20 or higher
CODESYS Control Win SL V3.5.17.20 or higher
Runs on Windows 8 / 10 / Embedded (32/64-bit) with multicore CPUs
Additional requirements
Installation of CODESYS Control Win SL
No ” hard” real time / Soft real-time properties: within the tolerance range time can be exceeded frequently and, secondly, rarely by a large amount.
08.03.2023
13.12.2022
06.10.2022
Includes the following Security fixes: 2022-09, 2022-10
03.06.2022
Includes the following Security fixes: 2021-09, 2021-11, 2021-12, 2022-02, 2022-03, 2022-04, 2022-06, 2022-07
06.04.2022
- 02.02.2023
- 28.10.2022
- 10.06.2022
- 25.01.2022
03.11.2021
23.07.2021
28.04.2021
- 27.07.2022
26.05.2021
28.01.2021
19.11.2020
Main update with improvements and bug fixes.
22.06.2020
19.09.2019
23.08.2019
- 18.04.2019
20.02.2019
17.12.2018
