This product allows users to program different models of the WAGO Touch Panels 600 by using the free CODESYS Development System (V3).
CODESYS Control for WAGO Touch Panels 600 SL is a SoftPLC-based on CODESYS V3 for the WAGO Touch Panels 600 series. After installation of the runtime environment, the PLC can be engineered with the CODESYS Development System (V3).
Detailed information about commissioning of the PLC can be found in the CODESYS Online Help.
Fully-adapted CODESYS runtime system for WAGO Touch Panels 600 series (https://www.wago.com/de/)
Suitable for PLC tasks with higher performance requirements
Comprehensive engineering solution with the free CODESYS Development System (V3), extensible by add-ons from the CODESYS Store
CODESYS Multicore is included as full version in the delivery of the runtime package.
CODESYS OPC UA Server is included as full version in the delivery of the runtime package.
CODESYS WebVisu is included as full version in the delivery of the runtime package.
Integration of existing C code
Implementation of external functions
Support of start/stop switches
Usage of local I/Os
Use of external event tasks
Connect persistent memories (Retains)
The following fieldbuses are included as full version in the delivery of the runtime package:
CODESYS CANopen Manager / Device
CODESYS EtherCAT Master
CODESYS EtherNet/IP Scanner / Adapter
CODESYS J1939
CODESYS Modbus TCP Master / Slave
CODESYS Modbus Serial Master / Slave
CODESYS PROFINET Controller / Device
Additonal products can be licensed for a fee:
CODESYS BACnet SL
CODESYS KNX SL
CODESYS Redundancy SL
Programming System | CODESYS Development System V3.5.17.0 or higher |
Runtime System | CODESYS Control V4.6.0.0 based on CODESYS Runtime Toolkit V3.5.18.30 |
Supported Platforms/ Devices | WAGO Touch Panels 600 Note: Use the tool “Device Reader” to find out the supported features of your device (free of charge component of CODESYS Development System). |
Additional Requirements | See license agreement. After installation, the user is responsible for implementing and checking the functionality of the combination of the software package and hardware according to device specifications.
Restrictions | |
Licensing | ![]() Single Device License: The license can be used on the target device/PLC on which the CODESYS Runtime System is installed. Licenses are activated on a software-based license container (soft container), which is permanently connected to the controller. Alternatively the license can be stored on a CODESYS Key (USB-Dongle). By replugging the CODESYS Key, the license can be used on any other controller Note: In demo mode, the software runs for two hours without a license. After that, a manual restart is required. |
Required Accessories | Optional: CODESYS Key |
