CODESYS Control for Raspberry Pi MC SL is an adapted CODESYS Control runtime system for Raspberry Pi with more than one core on a single CPU.
4.7.0.0
2302000032
€110.00
CODESYS Control for Raspberry Pi SL contains a multicore capable CODESYS Control runtime system for all Raspberry Pi models whose CPU has multiple cores, including compute modules (see http://www.raspberrypi.org/), as well as their possibility to use expansion hardware such as Raspberry PiFace Digital, Raspberry Pi Camera and various devices/boards with SPI, I²C or 1-wire interface.
After the installation of the runtime environment, the Raspberry Pi can be programmed as PLC with the CODESYS Development System.
This product can be installed with the included CODESYS Deploy Tool plug-in via the CODESYS Development System on the Raspberry Pi’s Linux system. After each restart the runtime system will be started automatically. If no valid full license can be found, CODESYS Control runs for two hours without functional limitations before shut down.
Detailed information can be found in the Online Help.
Benefits
  • Extended version of CODESYS Control for Raspberry Pi SL including multicore support (all CPUs)
  • Extension of the CODESYS Development System for binding individual IEC applications to different CPU cores
  • Debugging of the multicore application within CODESYS
Interfaces
  • CODESYS OPC UA Server, as full version for data exchange
  • CANopen via EL6751 Gateway
The CODESYS device description does support the following components:
  • Raspberry Pi Camera
  • I²C interface, with SenseHat, SRF02, Adafruit PWM, MPU6050 Gyro, MPU9150 Gyro, AK8975 Compass
  • SPI interface, with MCP3008, MCP23S17, PiFace Digital, PiFace Control Display
  • One-wire interface, with DS20B18
  • GPIO
SL Extension
  • Usage of local I/Os
  • Use of external event tasks
Fieldbus support
  • CODESYS EtherCAT Master
  • CODESYS J1939
Product options
  • CODESYS BACnet SL
  • CODESYS KNX SL
  • CODESYS SoftMotion SL
CODESYS Control V4.6.0.0 based on CODESYS Runtime Toolkit V3.5.18.30
  • Raspberry Pi 2
  • Raspberry Pi 3 / Compute Module 3
  • Raspberry Pi 4 / Compute Module 4
  • The CODESYS Control requires a network interface (LAN, WLAN), especially with the Raspberry Pi Compute Module and the Raspberry Pi ZERO.
  • If the product is used for industrial purposes, it is the responsibility of the system manufacturer to ensure compliance with the necessary specifications.
  • The operating system Raspberry Pi OS (32-bit) https://www.raspberrypi.org/downloads/
    • libm.so.6
    • libpthread.so.0
    • libdl.so.2
    • librt.so.1
    • libc.so.6
    • libgcc_s.so.1
  • The runtime system does not have real-time behavior. Its Jitter depends on many factors, especially on parallel executed Linux applications, and is ideally approximately 50 µs with maximum values of approximately 400 µs.
  • SD-card (minimum 4GB)
  • Optional: CODESYS Key
25.01.2023
27.10.2022
30.06.2022
- 01.03.2022
01.09.2021
Important Note
  • Fixed problem with GPIO outputs
Compatiblity information
Known limitations
16.06.2021
04.03.2021
04.12.2020
Quality update with minor improvements and bug fixes. Includes fix for latest Raspberry Pi OS version.
  • Quality update with minor improvements and bug fixes
  • Support of Pi4
19.09.2019
  • Support the new model Raspberry Pi 3 Model A+
  • Removal of SoftMotion widget type="Codesys\AllVersionWidget\Block\Widget\AllVersion" - available as separate product
23.08.2019
18.04.2019
20.02.2019
  • Includes security fixes 2018-07 to 2018-14 (Details)
14.12.2018
