This product will be replaced by the new platform-independent, application-based software licenses on 12/31/2023. For more information on application-based licenses, click here.
CODESYS Control for PLCnext MC SL
The CODESYS Control for PLCnext MC SL is an extension of the CODESYS Control for PLCnext SL, an adapted CODESYS Control runtime system for the Phoenix PLCnext controller AXC F 2152 or AXC F 1152.
