This product will be replaced by the new platform-independent, application-based software licenses on 12/31/2023. For more information on application-based licenses, click here. Please note that the usage of the application-based licenses requires the CODESYS Development System V3.5.19.10 or higher and a Control SL Runtime V4.9.0.0 or higher.
CODESYS Control for PFC100 SL
This product allows users to program the WAGO PFC100 controller by using the free CODESYS Development System (V3).
4.10.0.0
2302000019
€110.00
CODESYS Control for PFC100 SL is a SoftPLC-based on CODESYS V3 for the WAGO PFC100 industrial PLC. After installation of the runtime environment, the PLC can be engineered with the CODESYS Development System (V3).
  • Download of the product “CODESYS Control for PFC100 SL” from the CODESYS Store (http://store.codesys.com)
  • Installation of CODESYS SoftPLC on a WAGO PFC100 device (http://www.wago.com)
Benefits
Interfaces
SL Extension
  • Usage of local I/Os
  • Use of external event tasks
  • Connect persistent memories (Retains
Fieldbus support
  • CODESYS CANopen Manager / Device (except 750-8102 / -8112)
  • CODESYS EtherCAT Master
  • CODESYS J1939
  • CODESYS Modbus Serial Master / Slave (only 750-8102 / -8112)
Product options
  • CODESYS KNX SL
  • CODESYS Redundancy SL
All models of the WAGO PFC100 family
  • Minimum WAGO firmware version 17
    • libm.so.6
    • libpthread.so.0
    • libdl.so.2
    • librt.so.1
    • libc.so.6
    • libgcc_s.so.1
    • libdbus-glib-1.so.2
    • libdbuskbuscommon.so.0
    • libffi.so.6
    • libglib-2.0.so.0
    • liblibloader.so.0
    • libnvram.so.0
    • libuio.so.0
    • liboms.so
    • libtypelabel.so
    • libdiagnostic.so
  • The software package does not support hardware-specific model variations.
Major Features of new version
  • Update to CodeMeter V7.60c
31.10.2023
- 27.07.2023
05.04.2023
25.01.2023
27.10.2022
30.06.2022
  • Update to CodeMeter V7.40
01.03.2022
06.12.2021
01.09.2021
Important Note
Compatiblity information
Known limitations
16.06.2021
04.03.2021
04.12.2020
  • Support of WAGO firmware version 03.00.35(12)
23.08.2019
18.04.2019
20.02.2019
17.12.2018
18.01.2019
23.10.2018
10.07.2018
13.11.2018
24.05.2018
27.04.2018
26.02.2018
 - 20.12.2017
For more details see:
20.04.2018
16.02.2018
 - 21.09.2017
 - 22.08.2017
 - 17.07.2017
