CODESYS Control for emPC-A/iMX6 Multicore SL
The CODESYS Control for emPC-A/iMX6 Multicore SL is an extension of the CODESYS Control for emPC-A/iMX6 SL, an adapted CODESYS Control runtime system for the real-time capable industrial controller emPC-A/iMX6 from Janz Tec AG.
4.7.0.0
2302000037
€55.00
CODESYS Control for emPC-A/iMX6 Multicore SL extends an existing emPC-A/iMX6 controller from Janz Tec AG, on which CODESYS Control for emPC-A/iMX6 SL is installed, to a multicore (MC) high-performance PLC. This can process its IEC application specifically on multiple CPU cores. The system is suitable for applications with demands on the real-time behavior.
Benefits
  • Extension of CODESYS Control for emPC-A/iMX6 SL for multicore support (all CPUs)
  • Extension of the CODESYS Development System for binding individual IEC applications to different CPU cores
  • Debugging of the multicore application within CODESYS
Fieldbus support
The fieldbuses of CODESYS Control for emPC-A/iMX6 SL are supported in single-core operation.
Product options
CODESYS Control for emPC-A/iMX6 SL V4.6.0.0 based on CODESYS Runtime Toolkit V3.5.18.30
Janz Tec emPC-A/iMX6
Installation of CODESYS Control for emPC-A/iMX6 SL
- 25.01.2023
- 27.10.2022
- 30.06.2022
- 01.03.2022
01.09.2021
Important Note
Compatiblity information
Known limitations
16.06.2021
04.03.2021
04.12.2020
19.09.2019
  • Support of CODESYS Multicore
