Search results for: 'OSCAT+CONTROL'
CODESYS Application Composer S 2111000030 Subscription€350.00The CODESYS Application Composer enables, for modular machines, the efficient, no-code creation and complete generation of suitable control applications of all sizes by combining and parameterizing multi-modal software modules.
Data Analyzer S Project 2315000013€0.23Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
200 data points
500 records per hour
Only available as a service of the CODESYS Automation Server product. Bookable at My Account -> My Servers -> Details -> Add Services.
Data Analyzer XXS Project 2315000011€0.07Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
25 data points
100 records per hour
Data Analyzer XS Project 2315000012€0.14Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
50 data points
250 records per hour
Data Analyzer EVAL Project 2315000010€0.00Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
10 data points
10 records per hour
CODESYS Application Composer L 2111000032 Subscription€1,400.00The CODESYS Application Composer enables, for modular machines, the efficient, no-code creation and complete generation of suitable control applications of all sizes by combining and parameterizing multi-modal software modules.
CODESYS Automation Server 2315000005 Subscription€0.00With the CODESYS Automation Server, you can manage, monitor, and control your automation landscape remotely. Update, debug, and maintain your CODESYS projects and applications at any location—all via secure, centralized access to all your connected devices and associated CODESYS projects.
Data Analyzer M Project 2315000014€0.28Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
500 data points
1.000 records per hour
Data Analyzer L Project 2315000015€0.36Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
1.000 data points
2.500 records per hour
Data Analyzer XL Project 2315000016€0.50Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
2.500 data points
5.000 records per hour
Data Analyzer XXL Project 2315000017€0.83Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
5.000 data points
10.000 records per hour
Data Analyzer XXXL Project 2315000018€1.39Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
10.000 data points
20.000 records per hour
Data Analyzer MAXIMUM Project 2315000019€2.22Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
30.000 data points
50.000 records per hour
CODESYS Application Composer XL 2111000033 Subscription€2,800.00The CODESYS Application Composer enables, for modular machines, the efficient, no-code creation and complete generation of suitable control applications of all sizes by combining and parameterizing multi-modal software modules.
CODESYS EtherNet/IP Scanner SL 2303000007€150.00CODESYS EtherNet/IP Scanner is an additional option for controllers that are compatible with CODESYS. These devices are based on standard Ethernet ports to become EtherNet/IP scanners. The bus is configured from within the CODESYS Development System. Device configured in this way exchange real-time Ethernet messages with connected EtherNet/IP adapters.
CODESYS HMI SL 2304000009From €440.00
HVAC Building Automation Package SL 2312000005€100.00The HVAC Building & Process Automation SL package contains field-tested function blocks and HTML5 visualization macros for building automation applications. It includes libraries for HVAC control, BACnet communication, Modbus integration, alarm management, and CSV data logging.The package is optimized for rapid engineering with the CFC editor and includes complete project templates for quick start development.For more information: https://support.powerio.com/hub/codesys-hvacWithout license acquisition (download only), the HVAC Building & Process Automation SL operates for 30 minutes without functional limitations (Demo).Learn More -
CODESYS Academy Training V3 Essentials ONLINE 2108100021-T-2027-02-01€1,716.00Available: 8 of 9Feb 1, 2027 (08:30 CET) - Feb 5, 2027 (12:30 CET)
OnlineLearn MoreOrganizer: CODESYS GmbH
Place: Online
Language: EN
Event duration: Daily (from-to) 08:30 am- 12:30 pm
Registration must be completed by Thursday of the preceding week.
The online training is intended to teach the participants the handling of the CODESYS V3 programming system, the interaction with a CODESYS V3 controller and the general creation of an application according to IEC61131-3. This training is aimed at beginners in the CODESYS world, but is also suitable for those who are changing from CODESYS V2.3.
CODESYS Academy Training V3 Essentials ONLINE 2108100021-T-2027-01-11€1,716.00Available: 8 of 9Jan 11, 2027 (08:30 CET) - Jan 15, 2027 (12:30 CET)
Place: Online
Language: DE
CODESYS Academy Training V3 Essentials ONLINE 2108100021-T-2026-11-16€1,716.00Available: 8 of 9Nov 16, 2026 (08:30 CET) - Nov 20, 2026 (12:30 CET)
Place: Online
Language: EN
Event duration: Daily (from-to) 08:30 am - 12:30 pm
CODESYS Academy Training 3 Essentials 2108100015-T-2027-01-19€1,716.00Available: 7 of 9Jan 19, 2027 (08:30 CET) - Jan 21, 2027 (16:30 CET)
Memminger Straße 151, 87439 KemptenLearn MoreOrganizer: CODESYS GmbH
Place of event: CODESYS GmbH, Memminger Straße 151, 87439 Kempten
Language: DE
The three-day on-site training is intended to teach the participants the handling of the CODESYS V3 programming system, the interaction with a CODESYS V3 controller and the general creation of an application according to IEC61131-3. This training is aimed at beginners in the CODESYS world, but is also suitable for those who are changing from CODESYS V2.3.
CODESYS AI Workshop Series in Switzerland - Le Bouveret 2008100001€110.00Available: 14 of 14Oct 15, 2026 (09:00 CEST) - Oct 15, 2026 (16:00 CEST)
Route des, Aux Belles Truches 2, 1897 Le BouveretLearn MoreIn this workshop, you will gain practical insights into how generative AI can support engineering with CODESYS, from code generation and documentation to application testing. Together with CODESYS experts and experienced system partners, you will set up the required tools and explore concrete use cases directly within the CODESYS Development System.
The workshop includes hands-on exercises, an introduction to the Model Context Protocol (MCP), and real-world examples of AI-supported engineering workflows. This provides you with a solid basis for evaluating and implementing AI technologies in your own automation and control projects.
Event Language: French & English
CODESYS AI Workshop Series in Switzerland - Zofingen 2008100002€110.00Available: 18 of 20Oct 14, 2026 (09:00 CEST) - Oct 14, 2026 (16:00 CEST)
Strengelbacherstrasse 27, 4800 Zofingen, SchweizLearn MoreIn this workshop, you will gain practical insights into how generative AI can support engineering with CODESYS, from code generation and documentation to application testing. Together with CODESYS experts and experienced system partners, you will set up the required tools and explore concrete use cases directly within the CODESYS Development System.
Event Language: German
CODESYS AI Workshop Series in Switzerland - Rapperswil-Jona 2008100003€110.00Available: 20 of 20Oct 13, 2026 (09:00 CEST) - Oct 13, 2026 (16:00 CEST)
Oberseestrasse 10, Postfach 1475, 8640 Rapperswil-Jona, SchweizIn this workshop, you will gain practical insights into how generative AI can support engineering with CODESYS, from code generation and documentation to application testing. Together with CODESYS experts and experienced system partners, you will set up the required tools and explore concrete use cases directly within the CODESYS Development System.
Event Language: GermanLearn More -
CODESYS Academy Training 3 Essentials 2108100015-T-2026-10-13€1,716.00Available: 7 of 9Oct 13, 2026 (08:30 CEST) - Oct 15, 2026 (16:30 CEST)
Date: 13.10.2026- 15.10.2026
Daily: (from - to): 08:30 a.m. - 04:30 p.m. (CEST)
Language: DE
