Search results for: 'Codesys 1''
- codesys products 218
- codesys++products 218
- codesys product 218
CODESYS SoftMotion Axes (64) 2305000014€580.00CODESYS SoftMotion Axes extends the functional range of CODESYS Control SL systems from pure logic to motion control with optional support for CNC and robotics.
CODESYS SoftMotion Axes (48) 2305000013€510.00CODESYS SoftMotion Axes extends the functional range of CODESYS Control SL systems from pure logic to motion control with optional support for CNC and robotics.
CODESYS SoftMotion Axes (32) 2305000012€430.00CODESYS SoftMotion Axes extends the functional range of CODESYS Control SL systems from pure logic to motion control with optional support for CNC and robotics.
CODESYS SoftMotion Axes (16) 2305000011€320.00CODESYS SoftMotion Axes extends the functional range of CODESYS Control SL systems from pure logic to motion control with optional support for CNC and robotics.
CODESYS SoftMotion Axes (8) 2305000010€220.00CODESYS SoftMotion Axes extends the functional range of CODESYS Control SL systems from pure logic to motion control with optional support for CNC and robotics.
CODESYS SoftMotion Axes (4) 2305000009€160.00CODESYS SoftMotion Axes extends the functional range of CODESYS Control SL systems from pure logic to motion control with optional support for CNC and robotics.
CODESYS Safe Control 32 2306000008From €339.00
CODESYS Safe Control 24 2306000007From €259.00
Upgrade to CODESYS Control Performance XL 2302000069€949.00The application-based CODESYS Control Performance XL license is specially designed for applications with the highest performance requirements. The function of pinning task groups to isolated cores enables a significant reduction in task jitter. The license also includes 16 complex fieldbus instances (up to eight as host) and 65535 I/O channels. It can be used on all Control SL products without restrictions.
Upgrade to CODESYS Safe Control 192 2306000005€699.00Our application-based licence for functional safe PLCs offers you maximum flexibility and cost efficiency. The licence is based on the number of safe connections and allows up to 192 safe connections. Perfect for tailored safety in your automation system.
Upgrade to CODESYS Safe Control 64 2306000004€489.00Our application-based licence for functional safe PLCs offers you maximum flexibility and cost efficiency. The licence is based on the number of safe connections and allows up to 64 safe connections. Perfect for tailored safety in your automation system.
Upgrade to CODESYS Safe Control 16 2306000003€199.00Our application-based licence for functional safe PLCs offers you maximum flexibility and cost efficiency. The licence is based on the number of safe connections and allows up to 16 safe connections. Perfect for tailored safety in your automation system.
Upgrade to CODESYS Safe Control 8 2306000002€139.00Our application-based licence for functional safe PLCs offers you maximum flexibility and cost efficiency. The licence is based on the number of safe connections and allows up to 8 safe connections. Perfect for tailored safety in your automation system.
Upgrade to CODESYS Safe Control 32 2306000008€339.00Our application-based licence for functional safe PLCs offers you maximum flexibility and cost efficiency. The licence is based on the number of safe connections and allows up to 32 safe connections. Perfect for tailored safety in your automation system.
Upgrade to CODESYS Safe Control 24 2306000007€259.00Our application-based licence for functional safe PLCs offers you maximum flexibility and cost efficiency. The licence is based on the number of safe connections and allows up to 24 safe connections. Perfect for tailored safety in your automation system.
PROFIsafe V2.6 2306000006€100.00Licence to use the PROFINET V2.6 host functionality including TCI-based tools and i-Par server for application-based CODESYS safety controllers.
CODESYS SoftMotion Light SL 2305000002€192.00CODESYS SoftMotion Light extends the functional range of CODESYS Control SL systems from pure logic to motion control.
CODESYS SoftMotion Axis Groups/CNC Interpolators (6) 2305000020€800.00CODESYS SoftMotion Axis Groups/CNC Interpolators extends the functional range of CODESYS Control SL systems from pure logic to motion control with support for CNC and robotics.
CODESYS SoftMotion Axis Groups/CNC Interpolators (5) 2305000019€680.00CODESYS SoftMotion Axis Groups/CNC Interpolators extends the functional range of CODESYS Control SL systems from pure logic to motion control with support for CNC and robotics.
CODESYS SoftMotion Axis Groups/CNC Interpolators (4) 2305000018€560.00CODESYS SoftMotion Axis Groups/CNC Interpolators extends the functional range of CODESYS Control SL systems from pure logic to motion control with support for CNC and robotics.
CODESYS SoftMotion Axis Groups/CNC Interpolators (3) 2305000017€440.00CODESYS SoftMotion Axis Groups/CNC Interpolators extends the functional range of CODESYS Control SL systems from pure logic to motion control with support for CNC and robotics.
CODESYS SoftMotion Axis Groups/CNC Interpolators (2) 2305000016€300.00CODESYS SoftMotion Axis Groups/CNC Interpolators extends the functional range of CODESYS Control SL systems from pure logic to motion control with support for CNC and robotics.
Upgrade to CODESYS Control Performance L 2302000054€599.00Upgrade of an already purchased application-based license (Base License) to the application-based license Performance L. The costs of the already purchased license (Base License) are fully credited.
Upgrade to CODESYS Control Performance M 2302000053€349.00Upgrade of an already purchased application-based license (Base License) to the application-based license Performance M. The costs of the already purchased license (Base License) are fully credited.
Upgrade to CODESYS Control Standard L 2302000052€199.00Upgrade of an already purchased application-based license (Base License) to the application-based license Standard L. The costs of the already purchased license (Base License) are fully credited.
