Azure IoT Hub Client
With the “Azure IoT Hub Client” library, CODESYS controllers can exchange messages with the “Azure IoT Hub” cloud service from Microsoft.
The library “Azure IoT Hub Client” is now part of the product IIoT Libraries SL and is no longer available as single product.
2111000026
The “Azure IOT Hub” cloud service from Microsoft directly links IoT devices. (For more detailed information, refer to https://azure.microsoft.com/en-us/services/iot-hub/). The “Azure IoT Hub Client” library provides function blocks for sending and receiving messages. A sample project demonstrates how to use the library.
Programming system
CODESYS Development System V3.5.13.0 or later
Runtime system
CODESYS Control V3.5.13.0 or later
Note: Use the “Device Reader” project for locating the functions supported by the PLC. The “Device Reader” project is available in the CODESYS Store free of charge.
Additional requirements
Microsoft Azure account with Azure IoT Hub service; Device Explorer
Workstation license
Required accessories
Reviews
Write Your Own Review
