BE KOLLMORGEN s300s700 CAN Demo
Single axis motion function blocks for Kollmorgen s300 & s700. By ordering a free trial license (request via shopping cart) it is possible to test the product for 30 days.
2112000002
0,00 €
Single Axis motion function block’s for Kollmorgen s300/s700 drive.
Programming system
CODESYS Development System Version 3.5.0.0 or higher
Supported Operating Systems
All
CANopen interface
Best Engineering
BEST Engineering Scandinavia AB
Sabelgatan 4
SE 25467, HELSINGBORG
SWEDEN
Phone: +46-42-456 45 00
info@best-engineering.net
Best Engineering
Sabelgatan 4
SWEDEN
